Microsoft Windows 10 (32-bit)
On trying to open my HP Pavilion desktop screen posted message that there was a problem with my Pin and a message to reset it which wouldn’t operate  also trying to use my password access it wouldn’t accept my password - any clues  Windows 10 was recently updated
1 REPLY 1
@Bruntobi41
If you use a Microsoft account for your Win10 access (you would know that because the login screen shows either a pin code or an email address), then you can go to the Microsoft account reset website: https://account.live.com/password/reset -or - go to the Sign in Microsoft Account website: https://login.live.com/
Then follow these instructions:
1) Click/tap on the Can't access your account link
2) Select why you can't sign into your account and click/tap on Next
3) Enter the email address of your Microsoft account, type in the characters displayed onscreen, and click/tap Next
4) Select how you would like to get your security code to verify your identity, click/tap Next
5) Enter your security code sent using the method selected in 4) above, click/tap Next
6) If you have enabled tw0-step verification, repeat steps 4) and 5) above using a different method to send you a different security code
7) Type in a new password, click/tap Next
😎 Your Microsoft account has been recovered -- click/tap on Next -- and you're done
I am a volunteer and I do not work for, nor represent, HP
