HP All-in-One PC 22-dd0000i (9FK23AV)
  • Power indicator on for power supply.
  • will not power on
  • no signs or noises.
1 REPLY 1
The HP AIO's have a quirk that may be solved by unplugging the power supply from the back of the PC and holding the power start button in for 30 seconds.  Then re-insert the power supply plug into the back of the PC and attempting a restart.  That is assuming the green light remains lited when the restart is attempted.
I'm not an HP employee.
Did this message answer your question? Please indicate below as an Accepted Solution!
Did you find this message useful? Click on the "Was this reply helpful" Yes button.
