Windows 11 Support Center. -
- HP Community
- Desktops
- Desktop Operating Systems and Recovery
- system cooling fan error detected system fan 90b
07-05-2023 12:14 AM
actually i found error last night that was "The system has detected that a cooling fan is not operating properly and system fan 90B"
and after some few hours the error was not detected ,and system diagnostics there was no any detection found
soo please help me guys what shuould i do ?
07-08-2023 03:47 PM
Hi @Amaryadav,
Welcome to the HP Support Community
I understand you are facing an issue with your HP computer 90B error. Not to worry I will help you to get a resolution to resolve the issue.
Please try the following Troubleshoots steps.
1. Turn off the Unit.
2. Disconnect the AC adapter.
3. Remove any discs from the disc drive.
4. Remove memory cards from the card reader slot.
5. Disconnect all nonessential peripheral devices, such as printers, scanners, external hard drives, and USB flash drives.
6. Disconnect the AC adapter press and hold the power button for approximately 15 seconds.
7. Reconnect the AC adapter, and then turn on the computer.
Step 2
Turn off the unit and please press and hold the Windows key + letter B key and the power button together for 30 seconds after 30 seconds, 1st release the power button but keep holding the Windows key and B key for ten more seconds and then release these two keys If done correctly, you will see the display flashing once. Please attempt it thrice as this step and Restart the unit
Step3
The unit has to be turned off, Press Win+ V while holding these two keys then Press the Power button, continue to hold all three keys for 30 seconds and then release the Power button first and then release these two keys Please attempt it thrice and then you may get a Pop-Up CMOS Check and it will restart the unit
Even if you don't get a Pop-up restart the unit manually after 3 attempts.
Click here and follow the steps
I hope this helps! Keep me posted.
A_Gayathri
HP Support Community Administrator.
