Windows 11 Support Center. -
- HP Community
- Desktops
- Desktop Wireless and Networking
- My ethernet connection does not work, but my wifi does
07-11-2019 01:20 AM
My ethernet connection does not work, but my wifi does. When I turn off wifi while leaving the computer connected to the router via an ethernet cable the there is no connection. The cable has been tested with another PC from the same router port and works. Device manager does not seem to show any non functioning network adaptors either. All networks adaptors have been checked for latest drivers. There is no obvious ethernet connector showing as a a network adaptor devices so I'm starting to think that if still installed it is not recognised.
Any suggestions?
07-11-2019 03:41 AM
Your machine has Realtek Ethernet Controller for wired network and its support page does not have drivers for Windows 10
Please read the following document
https://support.hp.com/au-en/document/c06210209
Please try
https://support.hp.com/au-en/document/bph07165
Regards.
07-19-2019 06:17 AM
Thanks Banhien for your help. Its taken me some time to work through the leads you gave me but I've ended up going around in circles trying to find a driver for the Realtek Ethernet Controller.
The other complication is that when I go to Device manager/network adaptors I cannot see the Realtek Ethernet Controller listed there. Without it being listed I don't know how to look for win10 drivers for it or install them if I can find them.
Do you have any further leads. Thanks ... Frank
