None of the HP people know what they are talking about. Let me guide you through this. Fairly simple fix.
Go to Control Panel
Network and Internet
Network Connections.
Right Click on your network adaptor and click properties.
Click Configure
Click advanced
Under Advanced you will see property on the left and value on the right do the following
Property Value
IPv4 Checksum Offload (disbaled)
Large Send Offload IPv4 (disbaled)
TCP Checksum Offload IPv4 (disbaled)
UDP Checksum Offload IPv4 (disbaled)
Speed & Duplex (whatever Highest Value Available with Full Duplex)
Click Ok
Do a speed test and it should be good to go
Cheers
Give a thumbs up if this worked for you.
