Windows 11 Support Center. -
- HP Community
- Desktops
- Desktop Wireless and Networking
- Problems with wireless keyboard and mouse connection
12-26-2019 08:27 AM - edited 12-26-2019 12:48 PM
Good afternoon.
I have an HP Pavilion Wave Desktop 600-a0xx and for a while now the wireless keyboard and mouse don't work well.
I opened its case, extracted the USB dongle and connected it to another PC and both the keyboard and mouse started working normally, which is why I noticed that the problem is not with the USB dongle.
Has anyone had the same problem?
I would be very grateful for any information that could help me solve the problem.
Thanks in advance.
Solved! Go to Solution.
12-28-2019 11:14 AM
@J_Mauritius
Thank you for posting on HP Support Community.
Don't worry as I'll be glad to help, I have a few troubleshooting steps we could try to fix the issue:
Before troubleshooting startup issues, remove or disconnect all discs and devices from the computer.
- Step 1: Remove discs and devices
- Step 2: Perform a hard reset
- Step 3: Run hardware diagnostic tests
- Step 4: Refresh or reset your PC. Click here: https://support.hp.com/in-en/document/c04718479 to complete the troubleshooting steps. By end of the article, you will be able to fix the issue.
And also Perform Windows Update and HP Support Assistant:
To check for updates now, select the Start button, and then go to Settings > Update & security > Windows Update, and select Check for updates.
Install updates from HP Support Assistant: Go to Download HP Support Assistant to install the tool.
- To open the HP Support Assistant, double-click the HP Support Assistant icon
. - Click My devices in the top menu, and then click Updates in the My PC.
- Click Check for updates and messages to scan for new updates.
- Review the list of updates. Updates with a yellow information icon are recommended. Updates with a blue information icon are optional.
- Click the update name for a description, version number, and file size.
- Select the box next to any updates you want to install, and then click Download and install.
And, also run BIOS Update: Follow steps from the link: https://support.hp.com/in-en/document/c00042629
HP PCs - Wireless Keyboard and Mouse Connection Issues: https://support.hp.com/in-en/document/c00006821
Hope this helps! Keep me posted for further assistance.
ECHO_LAKE
I am an HP Employee
12-28-2019 11:14 AM
@J_Mauritius
ECHO_LAKE
I am an HP Employee
