@aphilip
Greetings!
Welcome to the HP Community. This is a great place to get support, find answers and tips to your technical queries. I have reviewed your post and I understand, there's an issue with the network speed.
Don't worry, I'm here to help! To better assist you - Are you using a single band or a dual-band router?
While you respond to that, A few things to remember are mentioned below:
The compatibility of your router with the wireless card -
- If the wireless card is 1x1: supports 2.4 GHz and below - slow connection and download/upload speed.
- If it's 2x2 or more: support 5 GHz and above - Fast connected and speed.
In the meantime, you may also try the steps mentioned in this document.
Let me know.
To help the community find this post, click here to access our public post and Select - "Accept as solution", have a good day.
Have a great day!
Asmita
I am an HP Employee
