HP U27 4K Wireless Monitor
I can't connect wirelessly to one of my U27 4K Wireless Monitors.
This means I can't use the HP Quick Pair app for a firmware upgrade to try if the issue is solved after an upgrade.
As a firmware upgrade by using an USB stick was also mentioned in the Quick Pair app, where can I download the firmware (without using the app)? And how do I perform the upgrade by using an USB stick?
I have a second U27 4K Wireless Monitor where the firmware upgrade (wireless) was executed without issues.
Thanks in advance for a solution,
Petrus
