Ready to level up? Join the Expert Program—
HP Envy 15 X360 PC
My battery is supposedly irreplaceable.  I really dont want to throw this computer away.  Can I replace it, where do I find a battery.  Battery is losing power daily.   Someone on here a few weeks ago said they would see if they could find a battery for me but I didn't get a response.  Anything I can do?  I am technically challenged so I need HELP!  Thank you.
1 REPLY 1
Hi @JJ429
  I'd suggest you Contact HP in your region regarding the service options for your computer.
If you are having trouble navigating through the above options, it's most likely because the device is out of warranty. If yes? please send me a private message with the region you are contacting us from. Check next to your profile name, you should see a little blue envelope, please click on it.
Have a great day!
