  • Laptop not charging and led light not glowing .
  • Your hp service team told that update bios and after updating bios and perforinpe different test ,the hp service team didn't solve the battery issue.
  • I have case I'd and they automatically closed without any call to me .
  • I thought HP provide good service but your team didn't provide any better service.That is I  m writing my laptop problem here ,so kindly do some solution
1 REPLY 1
@Manpreet98
Did you try using a different charger?
Let's perform the below steps to resolve the issue:
Step 01. Click on the Start Button
Step 02. Type "Device Manager" in the start search box & open the Device Manager
Step 03. Look for Batteries and expand it by click on the + symbol on the left
Step 04. Right Click on "Microsoft ACPI Compliant Control Method Battery" & uninstall
Note: This Battery driver will get re-installed automatically when you restart the Notebook again
Step 05. Please Shutdown the Notebook
Step 06. Please remove the Battery and unplug the Power Adapter (If the battery is removable)
Step 07. Press and Hold the Power Button for full 1 Minute
Step 08. Go ahead and put back the Battery and connect the Power Adapter
Step 09. Look for "Plugged In Charging" message on the Battery icon
After performing all the steps if you are facing the same issue still, please perform three more steps:
1. Run a Battery Check in HP Support Assistant[Install the Software if it's not available]
Note: Replace the Battery If Health Check Status shows Replace
2. Update the latest BIOS for your Notebook from HP Support Site
3. Please check your Notebook with a known good Power Adapter & Battery from a different Notebook
Note: If a known good battery is also not charging we need to replace the system board
How to improve the life of a Battery:
1. Power Plan should be set correctly for extended battery life
2. Please keep the Screen Brightness at a lower level
3. Please turn OFF Wi-Fi Connection when not in use
4. Please remove the CD/DVD's from the Optical Drive when not in use
Testing and Calibrating the Battery (Windows 10)
http://support.hp.com/my-en/document/c04700771
If the issue persists, update the BIOS using the below link:
Click here: https://support.hp.com/us-en/drivers
Keep me posted, how it goes!
If the information I've provided was helpful, give us some reinforcement by clicking the Accepted Solution and Kudos buttons, that'll help us and others see that we've got the answers!
Thank you for joining the HP Community.
Have a great day!
Cheers:)
Raj1788
I am an HP Employee
