Windows 11 Support Center. -
- HP Community
- Notebooks
- Notebook Operating System and Recovery
- Plugged in not charging, unknown battery test, and no batter...
04-27-2019 07:08 PM
Hello,
My battery is currently at 0% and I am having the plugged in, not charging issue with my battery. This would happen to me occasionally and I was always able to fix it by removing the battery and putting it back on. However, that didn't work this time and I have also try 3 other solutions mentioned in other posts.
1. Device manager and uninstalling the the Microsoft ACPI - Compliant Control Method Battery, shut down laptop, unplug charger, remove battery, press and hold on the power button for a minute, leave the laptop for 2-3 minutes, put the battery and charger back on, and power on the laptop = did not work
2. HP Support Assistant --> Battery check = did not work, my test result said "Unknown" and did not provide any other information.
3. HP System Diagnostics for Testing and Calibrating the Battery --> Battery Test = did not work , received error message that said No Battery is Installed (but the battery is installed)
I am confident that both my laptop battery and charger are still in good condition (they are both the official replacement I bought about 2 years ago from the HP store.
if there are any other solutions to help with this issue, I would really appreciate it.
04-28-2019 12:08 PM
Hi @arid123
Try these steps -
Step 1 Hard Reset -
1) Shutdown the computer.
2) Unplug all the Adapter and peripherals connected.
3) Remove the Battery.
4) Press and hold down the power button for 15 to 20 seconds.
5) Plug-in the Adapter and put the Battery back into the computer.
6) Try to turn on the computer.
Step 2 BIOS Defaults -
2) Turn the computer back on again and repeatedly tap on the ESC until a Startup menu appears.
3) Press F10 once for BIOS.
4) Press F9 for BIOS defaults.
5) Press F10 to save and exit.
Test the battery using these steps -
3) Press F2 once.
4) Go to Component test.
5) From the list, run the Battery Test.
Let me know how that goes.
Have a great day!
Asmita
I am an HP Employee
04-29-2019 07:59 AM
This is a hardware issue.
Please reach out to the HP Support in your region regarding the service options for your computer.
Thanks!
Asmita
I am an HP Employee
04-29-2019 08:39 AM
It could be possible that your charging IC is damaged, I had the same issue replaced battery changed charger but nothing worked. I am using envy m6-1206tx laptop as a PC right now as I don't have any other option instead of using it as AC charger connected.
