On the command center--the system control page. My laptop doesn't show the fan speed and surface temperature even though the surface was really hot. Also my fan is not working. Can you help me out with this problem? Thank you in advance
Hi @User777887,
Thank you for posting your query, I will be glad to assist you.
I see that you are facing an issue with your Laptop fan that is not working.
Follow the below steps to fix the issue.
Perform a power drain on your PC.
1) Unplug the power cord from the PC & wall.
2) Disconnect the power cable from the AC adapter if it is a detachable part and keep it aside.
3) Press and hold the power button down for 15 seconds and release the power button, wait for about 30 seconds.
4) Plug the power cord back into the AC adapter, then connect it to the wall and to the charging port on your PC.
5) Power on the PC and Update the BIOS for your PC by clicking on the link.
Make sure you keep only the charger plugged in while updating the BIOS for your PC.
Click on the + sign next to BIOS and then download the file.
Open the file and follow the on-screen instructions to complete the update.
B) If the issue still persists, refer to the steps on this link to further troubleshoot.
Please mark this post as “Accepted Solution” if the issue is resolved and if you feel this reply was helpful click “Yes”.
I hope this helps.
Take care and have a great day ahead!
Irwin6
HP Support
Irfan_06-Moderator
I am an HP Employee
1 REPLY 1
Hi @User777887,
I hope this helps.
Irwin6
HP Support
Irfan_06-Moderator
I am an HP Employee
