HP OmniBook Ultra Flip 14 inch 2-in-1 Laptop Next Gen AI PC 14-fh0000 (9F2C2AV)
Hello,
I bought a new Omnibook Flip and have been having problems with the Wi-Fi from the very beginning.
All updates (BIOS, Windows, drivers, etc.) are installed.
I’ve noticed that I don’t have any problems when the power cord is plugged in.
However, when I unplug the power cord and run on battery power, the Wi-Fi connection drops every 2 seconds.
This prevents me from loading web pages normally. I recorded a video with and without the power cord plugged in. I also ran a speed test to illustrate my problem for you.
Can you help me, or is this a hardware issue that means I need to exchange the laptop?
My Problem (Notebook without Power Cable) - Speedtest drops every 2 Seconds; no Download of content:
https://jumpshare.com/s/J7K3q6FEIg5mDi2Xf2Mq
All works fine (Notebook with the plugged in Power Cable) - Speedtest works fine and I have a stable connection:
https://jumpshare.com/s/r1WLmayg3sF8ztDOjshr
4 REPLIES 4
Hi  @morpheus2026,
Welcome to the HP Support Community!
Thanks for reaching out!
I understand your concern, don’t worry let me help you with this.
Thank you for providing such detailed information, the videos could not be opened (error - file not found). I understand how this must feel on a brand-new HP OmniBook Ultra Flip, dont worry let me check and help you with this.
Could you kindly confirm the below details :
  • Are you connected to a 2.4 GHz network, 5 GHz network, or Wi-Fi 6/6E router?
  • Does the issue occur on all Wi-Fi networks, such as a mobile hotspot, or only on your home network?
  • Have you noticed whether Bluetooth devices are connected when the issue occurs?
  • When the connection drops on battery power, does the Wi-Fi icon disconnect completely, or does it remain connected but lose data throughput?
  • Have you already tested the notebook in Safe mode Networking ?  (Link for steps - Click here )
In the meantime, kindly try the following troubleshooting steps and confirm:
  1. Disable Wi-Fi Power Saving
    • Open Device Manager.
    • Expand Network adapters.
    • Right-click your wireless adapter and select Properties.
    • Go to the Power Management tab.
    • Uncheck Allow the computer to turn off this device to save power.
    • Click OK and restart the notebook.
  2. Change Wireless Adapter Power Settings
    • Open Control Panel -Power Options.
    • Select your active power plan and choose Change advanced power settings.
    • Expand Wireless Adapter Settings > Power Saving Mode.
    • Set both On battery and Plugged in to Maximum Performance.
    • Apply the changes and restart the system.
  3. Run HP Hardware Diagnostics (Link for steps for hardware UEFI test - click here )
    • Restart the notebook and repeatedly press F2 at startup.
    • Run the Wireless Module Test and note the results.
  4. Perform a Network Reset
    • Go to Settings -Network & Internet -Advanced network settings > Network reset.
    • Restart the PC after the reset completes.
  5. Reinstall the Wireless Driver
    • In Device Manager, uninstall the Wi-Fi adapter and check Delete the driver software for this device if available.
    • Restart the notebook and install the latest Wi-Fi driver from HP's support page https://support.hp.com/  for your model.
Based on your description, especially since the connection becomes stable immediately when AC power is connected, this may be related to wireless adapter power management rather than a hardware defect. However, the diagnostic results will help determine whether a repair should be considered.
I hope this helps.
I'm an HP Employee.
If this reply helped resolve your issue, please select the Accept as Solution as it helps others in the community quickly find the answer they’re looking for.
And if you found this reply helpful, clicking Yes below is a great way to let us know we’re providing the support you need, as it encourages us to keep improving and sharing helpful guidance.
I had a similar problem with a new laptop in 2024 that ran windows 11 and had a wifi 6 adapter. My problem was due to an older wifi 4 router. The confusing issue was that all other devices worked fine with the older router but the new laptop constantly dropped wifi when running on battery only and worked fine with the power adapter. I don't know if you have a similar problem but you can look at this old post:
https://h30434.www3.hp.com/t5/Notebook-Wireless-and-Networking/Poor-connection-where-power-cable-is-...
Hi Paul,
thank you for the reply.
I test my notebook with a Power-LAN WIFI and it works. 🙂
I find out, that my normal router uses Wi-Fi 5 and the Power Lan Repeater Wi-Fi 6.
The Problem must be the different Wi-Fi Version.
Are there any settings in the Protocols for Wi-Fi I can change on my notebook?
I hope a HP specialist can see this reply. @deep_world
I don't have any experience with Power LAN wifi devices. If you are referring to Powerline wifi devices like the TP-Link wpa8630 then my understanding is that the Adapter connects to the router via ethernet and that is modulated over the AC house wiring and broadcast to the Extender which contains wifi access point functionality. If I understand your post correctly you successfully connect to the extender wifi 6 access point when running on battery only --- and you cannot reliably connect to your wifi 5 compliant router. Your new laptop has either a wifi 6 or possibly wifi 7 adapter.
I don't know of any wifi 6 adapter Advanced setting that would account for your problem and I'm not familiar with wif 7 adapter settings.  I assume you checked the power settings that were recommended by Deep_World in the original posting as that could be a factor.
I would consider going to someplace like a public library and test the laptop there before you point a finger at your wifi 5 router. Every release of a new wifi standard is suppose to be backwards compatible, but then who is testing all the different hardware.
