HP OfficeJet 8022 All-in-One Printer
Model Name HP Officejet Pro 8030 Series Product Name 1L0H8A Model Number: 8035E (The printer carriage cannot move. Open the cartridge access door, clear any paper jam or obstruction, and select "OK". Result is a broken plastic white gear. How can this be ordered.
2 REPLIES 2
Hi @rgreen7313,
I'd like to help!
To get parts and fix this issue, you will need additional support from our internal teams in HP. For that to happen, we will give you additional instructions/information via Private Message.
Please check your inbox on the forums page for the private message.
If the information I've provided was helpful, give us some reinforcement by clicking the Accepted Solution button, that'll help us and others see that we've got the answers!
Nal_NR-Moderator
I am an HP Employee
Hi I saw this reply and need same help to get a replacement gear.  Small white plastic.  Thanks
