HP DeskJet 3750 All-in-One Printer
macOS 12.0 Monterey
Hi,
I have this issue with my printer that when I turn it on, the power button as well as the resume and wireless button immediatly start blinking, the control panel shows the letter E (see in picture).
3 REPLIES 3
@Lisa2911
Thank you for posting on the HP Support Community.
Don't worry as I'll be glad to help, to provide an accurate resolution, I need a few more details:
  • Did you make any changes to your printer?
  • Have you tried any troubleshooting steps?
While you respond to that, kindly perform the steps mentioned in this document - https://support.hp.com/in-en/document/c01082964 By the end of the article you will be able to isolate the issue.
Hope this helps! Keep me posted for further assistance.
Please click “Accept as Solution” if you feel my post solved your issue, it will help others find the solution. Click the “Kudos, Thumbs Up" on the bottom right to say “Thanks” for helping!
ECHO_LAKE
I am an HP Employee
Hello,
I have not made any changes. It happened over night. I tried various button combinations, but nothing seemed to be working. The printer doesn’t even turn off when I press the power button once. I also tried the steps listed in the sent link, but it didn’t help.
Thanks!
@Lisa2911
Thank you for posting back.
I appreciate your efforts to try and resolve the issue.
I'm sending out a private message to assist you with the next course of action. Please check your Private message icon on the upper right corner of your HP Community profile Next, to your profile Name, you should see a little blue envelope, please click on it or simply click on this link: https://h30434.www3.hp.com/t5/notes/privatenotespage
ECHO_LAKE
I am an HP Employee
