Featured blog article:
HP Sprocket 200 Printer
iOS
Every time i try to connect the printer to my app, it shows the printer and i press on it. but when it is loading to connect, it always ends up saying there is a “problem with setup”. i have tried restarting my phone and sprocket printer, but it still does not work.
1 REPLY 1
Hi @LilyL,
I read your post and i understand you're unable to print or connect to the printer.
I'd like to help, please try the below steps-
Confirm mobile device settings
Make sure your mobile device settings allow a connection with your Sprocket.
  1. Turn on the Sprocket.
  2. On your mobile device, open the Bluetooth settings menu, and then make sure Bluetooth is enabled.
  3. Check the settings on your Android or iOS device.
    • Android devices: On your mobile device, open the Location or Location Services menu, and then make sure the setting is turned on.
      NOTE:
      You can turn location permission on to connect and print, and then turn it off when you are not using the Sprocket.
      Location menu example on Android
    • iOS devices: Previously paired Bluetooth accessories such as Apple AirPods might interfere with the initial discovery of the Sprocket. Unpair the accessory from the Bluetooth menu of your device before initial pairing with your Sprocket. The accessory can then be paired again after the Sprocket is connected.
  4. On your mobile device, open the HP sprocket app.
  5. Tap the Menu icon , tap sprocket, and then tap Manage Printers.
    A list of available Sprockets displays.
    • If your Sprocket displays: The Sprocket is connected.
    • If your Sprocket does not display: Tap Add New Printer, and then tap the name of your Sprocket.
If the issue persists, continue to the next step.
Reset your mobile device and Sprocket
Reset your mobile device and Sprocket to clear any errors states.
  1. Turn off your mobile device, and then turn it back on.
  2. Turn on the Sprocket.
  3. Remove the Paper Cover, and then use a narrow object, such as a pen or paperclip, to press and hold the Reset button for 3 seconds until the Sprocket turns off.
    NOTE:
    The location of the Reset button varies by Sprocket model. Typically, the button is located underneath the Paper Cover, but can also be found on the outside next to the charging port.
    Example of resetting the HP Sprocket Select Photo Printer
  4. Turn on the Sprocket.
Upgrade the Sprocket firmware
HP regularly releases firmware updates. Upgrading the Sprocket firmware might resolve the issue.
  1. Make sure the Sprocket is on and your mobile device is connected to the Internet.
  2. On your mobile device, open the HP sprocket app.
  3. Tap the Menu icon , and then tap sprocket.
  4. Tap Manage Printers, make sure your Sprocket is selected, and then tap Printer Settings.
  5. Look for a firmware upgrade.
    • If a firmware upgrade displays, tap Get Firmware Upgrade, and then follow the on-screen prompts to complete the update.
    • If a firmware upgrade option does not display, the firmware is up-to-date
refer to  Sprocket Does Not Connect or Print
Click the “Kudos, Thumbs Up" on the bottom right to say “Thanks” for helping
