Windows 11 Support Center. -
- HP Community
- Desktops
- Desktop Operating Systems and Recovery
- Sound max driver problem
06-19-2017 01:19 PM
Hi:
If my memory serves me right (I don't have my dc7800 hooked up right now), there is a setting in the ADI soundmax control setting to enable multi-streaming.
Check that box and restart the PC.
That setting allows the front and back audio ports to work independently.
After you do that, you should now see a headphone setting to enable in the manage sound section of the control panel.
This is only going to work if you were able to successfully install the W7 Soundmax audio driver.
06-19-2017 10:17 PM
> recognized my microphone but it doesnt work.
Click the small "speaker" icon on the bottom-right of your "notification area".
Then, click "mixer".
Either "unmute" the microphone input, or move the slider to 100%, to see if that "pumps-up" the sound-level from the microphone into your computer.
06-20-2017 12:01 AM
I fixed it earlier through a forum and its good now but my headphones are so low i can barely hear anything on my other pc the headphones work correctly.
Everything is turned to the max on the volume options and when i ran the troubleshooter it said that everything is fine.
11-08-2018 07:54 AM
Hello,
Thank you for posting in this thread. Unfortunately based on when the last response was made, I have closed this thread to help keep comments current and up to date. We recommend starting a new thread for your issue.
To be more helpful with your post, you can add key information if you desire:
1. Product Name and Number (please do not post Serial Number)
• Example: HP Pavilion DV2-1209AX or HP Deskjet 3000 Printer CH393A
2. Operating System installed (if applicable)
• Example: Windows XP, Windows Vista 32-bit, Windows 7 64-bit
3. Error message (if any)
• Example: ""Low disk space"" error in Windows
4. Any changes made to your system before the issue occurred
• Examples: Upgrading your Operating System or installing a new software; or installing new hardware like a printer, modem, or router.
If you have any other questions about posting in the community, please feel free to send me a private message!
Thank you
I work on behalf of HP
