×InformationNeed Windows 11 help?Check documents and videos on compatibility, FAQs, upgrade information and available fixes.Windows 11 Support Center.
- HP Community
- Desktops
- Desktop Wireless and Networking
- Antenna for Ralink Technology 802.11n wireless lan card
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Mute
- Printer Friendly Page
12-21-2019 04:04 AM
I am missing the antenna(s) for the wireless card. As a result the wireless connection is very weak and not all available networks are showing. The card is working properly and the driver is up to date. I just need to replace the antenna(s). Are the antennas one size fits all? The hardware IDs are
PCI\VEN_1814&DEV_3090&SUBSYS_663211AD&REV_00
PCI\VEN_1814&DEV_3090&CC-028000
PCI\VEN_1814&DEV_3090&cc_0280
12-23-2019 05:06 PM
@kmbannar Welcome to HP Community!
The antenna is inbuilt, its not something you can purchase an connect to your device, I suggest you use the below steps to improve the wifi signal performance, instead:
Go to Device manager > select the WIFI drivers under network adapter> Right click go to properties > Under properties go to Power Management Tab> Uncheck "Allow the computer to turn off this device to save power".
If the issue persists, continue with the below steps:
If your computer has a wireless key or button on or near the keyboard and the wireless activity light is off or amber in color, then press the key or button to enable your wireless adapter. This key might be the F10 key, F12 key or labeled with a symbol of an airplane.
If wireless activity comes on or the activity light turns blue, you have enabled wireless on your system. Try connecting to the Internet again. If problems persist, continue using these steps.
If your computer does not have a wireless key or the wireless activity lights remains off or orange then continues using these steps.
Click Start, type troubleshooting into the Search field.
Select troubleshooting from the search results.
Click Network and Internet.
Click Internet Connections
For more details consider using the HP Guided Troubleshooter:
Click here to access it (simply select your description of the issue from the bottom of the screen to gain access to the next set of steps that should resolve your concern).
Keep us posted,
If you would like to thank us for our efforts to help you,
Give us a virtual high-five by clicking the 'Thumbs Up' icon below, followed by clicking on the "Accept as solution" on this post,
Have a great day!
Riddle_Decipher
I am an HP Employee
12-24-2019 12:15 PM
Hello. I previously tried the steps you listed. No luck. I googled the Ralink wireless card and it showed an external antenna. There is bolt (for lack of a better word) on the back of the tower where it would screw on. I have a wireless signal, it's just weak. Thank you for your time.
12-24-2019 06:25 PM
@kmbannar If you've feel there should be an external antenna and its missing, I suggest you talk to HP support and discuss your options, follow the below steps to get started:
1) Click on this link - http://www.hp.com/contacthp/
2) Click on Sign-in or select the product using the below step:
3) Enter the serial of your device.
4) Select the country from the drop-down.
5) Click on "Show Options".
Fill the web-form, to populate a case number and phone number for yourself!
Also, if you are having trouble navigating through the above options, it's most likely because the device is out of warranty, if yes? please send me a private message with the region you are contacting us from,
here's how private messages work: Click here for details.
If you wish to thank me for my efforts, you could click on "Accept as solution" on my post as the solution should help others too.
Riddle_Decipher
I am an HP Employee
Didn't find what you were looking for? Ask the community
