Windows 11 Support Center. -
- HP Community
- Notebooks
- Notebook Audio
- Re: Sound problem and mute led not working
06-12-2018 02:21 PM
Hello everyone
Ever since I had my laptop, I've been experiencing a sound onset delay for about 1-2 seconds each time I pause and restart some sound or video or whatever, whenever there's speakers or earbuds plugged in the 3.5 mm jack at the left of my laptop. When nothing is plugged in, the sound just works fine.
It's not that the sound starts playing after 1-2 seconds with a constant delay, but it just kicks in; it's like the audio has to be booted up each time I play a sound/song/video when speakers or earbuds are plugged in.
Additionally, I don't know for how long this has been, but the mute toggle led has stopped working (F6 key).
How can I solve these problems?
Thanks
M
Solved! Go to Solution.
06-12-2018 02:45 PM
Hi,
Try the following.
Download the Realtek HD Audio installer on the link below and save it to your Downloads folder.
https://ftp.hp.com/pub/softpaq/sp81001-81500/sp81471.exe
When done, hold down the Windows key and press R
Into the Run window, type devmgmt.msc and hit enter.
In Device Manager, expand Sound, Video and Game Controllers. Right click the Realtek device and select Uninstall - you should also get a prompt to remove the current driver, tick the box to allow this and then proceed with the uninstall.
When complete, download and reinstall the Chipset driver on the following link.
https://ftp.hp.com/pub/softpaq/sp82501-83000/sp82749.exe
When the Chipset reinstallation has completed, restart the notebook.
When windows has reloaded, open your Downloads folder, right click on the Realtek installer and select 'Run as Administrator' to start the installation. When this has completed, restart the notebook again and let windows fully load for a few minutes before checking.
Regards,
DP-K
****Click the White thumb to say thanks****
****Please mark Accept As Solution if it solves your problem****
****I don't work for HP****
Windows Insider MVP
06-12-2018 02:45 PM
Hi,
Try the following.
Regards,
DP-K
Windows Insider MVP
