Windows 11 Support Center. -
- HP Community
- Notebooks
- Battery Timing Problems | Battery not Detected
Common problems for Battery
11-24-2021 11:13 PM
Product: HP Probook 450 G2
Operating System: Microsoft Windows 10 (64-bit)
II changed laptop's battery 2 months ago. Since then, the battery timing was good but now it has been decreased. Moreover, in the HP Support Assitant, whenever I run Battery Check up, is says 'battery not detected'. Kindly help me, despite changing the battery with a new one, why the timing is still very low and why HP Support Assistant is not showing the battery. Are there any tests needed to be run?
Thank You
3 REPLIES 3
Ask the community
