Common problems for Battery
HP Spectre x360 14 inch 2-in-1 Laptop PC 14-eu0000 (7K633AV)
1. I seldom use the laptop but from the first week I encoutered sudden actions on the screen like I'm touching the screen, while I didn't do anything.
2. Although I don't use this laptop oftenly, after 6months the battery seems to drain within 5 to 10min.
1 REPLY 1
@pvanbeveren, Welcome to HP Support Community.
I understand you're experiencing two issues with your HP Spectre x360 14-eu0000, unexpected touchscreen behavior and rapid battery drain. Let's address both step-by-step:
Touchscreen Acting on Its Own (Phantom Touches)
This is often caused by hardware interference, driver issues, or environmental factors. Here's what you can try:
Clean the Screen
  • Use a soft, lint-free microfiber cloth to gently clean the screen. Smudges or moisture can sometimes cause false touches.
Update Touchscreen Drivers
  1. Press Windows + X → Select Device Manager.
  2. Expand Human Interface Devices.
  3. Right-click HID-compliant touch screen → Select Update driver → Choose Search automatically.
Calibrate the Touchscreen
  • Go to Control PanelHardware and SoundTablet PC Settings → Click Calibrate.
BIOS and Firmware Update
Perform a Touchscreen Diagnostic
  • Use the HP PC Hardware Diagnostics tool:
    • Press Esc repeatedly at startup → Press F2 → Choose Component Tests → Select Touch Screen Test.
Battery Draining Quickly After 6 Months
This could be due to battery wear, background processes, or a calibration issue.
Battery Health Check
  • Download and run HP Support Assistant: Download here
  • Go to Battery Check under My NotebookBattery.
BIOS Battery Test
  • Restart your laptop → Press Esc repeatedly → Press F2 → Select Component TestsPowerBattery Test.
Battery Calibration
I hope this helps.
Please click “Accepted Solution” if you feel my post solved your issue, it will help others find the solution. Select "Yes" on the bottom left to say “Thanks” for helping!
Max3Aj
HP Support
