Windows 11 Support Center. -
- HP Community
- Notebooks
- Laptop will not power on, power/charging LED blinks 9 times ...
Common problems for Battery
02-23-2020 02:18 PM
Product: probook 6470b
I have the local Cub Scout Pack's laptop because it will not turn on anymore.
With it plugged in I press the power button and the light on the front edge flashes 9 times and quits. That's it.
After a while the light comes on blinking amber.
What can I do?
Solved! Go to Solution.
5 REPLIES 5
03-03-2020 09:14 AM
This happened on my desktop pc and I had to remove the battery from the motherboard for a bit and then put it back in. After that it booted fine.
Web Designer: Word Finder | Software Engineer | HP User
Ask the community
