Here is the solution to resolve for 5 Long and 3 Short Blinks on your HP Laptop Click here to view the instructions!
Common problems for Battery
HP notebook be012tu
While charging the power Indicators started turning white then red in few min again white. It has started recently & I've not done any update during this period. when battery is not fully charged then how can led turns white below 80% or more less.
9 REPLIES 9
@Sushant_golu
Thank you for posting on the HP Support Community.
Don't worry as I'll be glad to help, however, to provide an accurate resolution, I need a few more details:
  • Have you made any hardware/software changes?
  • Did this happen after a recent window or software update?
  • Did you make any changes to the settings of your PC prior to the issue?
While you respond to that, let's try these steps:
Firstly, run Hard Reset: Follow steps from the link: https://hp.care/2GnkMa8 (if the computer doesn't start up/power on you can skip the next step)
Next step, BIOS default:
  1. Turn off the computer and wait five seconds.
  2. Press the Power button to start the computer and repeatedly press the F10 key to enter the BIOS setup menu.
  3. On the BIOS Setup screen, press F9 to select and load the BIOS Setup Default settings.
  4. Press F10 to Save and Exit.
  5. Use the arrow keys to select Yes, then press Enter when asked Exit Saving Changes?
  6. Follow the prompts to restart your computer.
Hope this helps! Keep me posted for further assistance.
Please click
Accept as Solution if you feel my post solved your issue, it will help others find the solution.
ECHO_LAKE
I am an HP Employee
Yes I guess it  is from earlier update. I just noticed few days back, don't know exactly when it started.
But pls tell me.... Is it any hardware failure?
@Sushant_golu
Thank you for posting back.
This sounds like hardware related issue with the computer, however, please complete the above troubleshooting steps to isolate the issue.
ECHO_LAKE
I am an HP Employee
I've completed both steps mentioned by you of troubleshooting. But it doesn't fix issue. Still led indicator switches light while charging. It's like, yesterday I drained battery and plugged in AC adapter when battery was 10% & in every few mins light switches to white for few secs then again return tu default Red" like this it keeps on switching. In random time span.
@Sushant_golu
Let's try these steps:
Run hardware diagnostics test on battery and Charger:
Use the following steps to open the Component Tests menu.
  1. Hold the power button for at least five seconds to turn off the computer.
  2. Turn on the computer and immediately press Esc repeatedly, about once every second. When the menu appears, press the F2 key.
  3. On the main menu, click Component Tests.
  4. The Component Tests menu displays. Your Component Tests menu might be different, depending on the components installed on your computer.
  5. To run both tests simultaneously, in the Component Tests menu, click Power Source, and then click Run once. Each component can also be tested individually.
AC Adapter Test:
The AC Adapter test provides an interactive test to determine if the AC power adapter is functioning properly. A good battery is required for this test. Before running the AC Adapter Test, HP recommends verifying that your computer can receive power by connecting a known working AC adapter.
Follow these steps to perform the AC Adapter Test.
  • In the Component Tests menu, click Power, and then click an AC Adapter Test.
  • Click Run once.
  • The AC Adapter Test begins.
  • When the test is complete, the results are displayed on the screen.
Battery Test:
Follow these steps to perform the Battery Test:
  1. In the Component Tests menu, click Power, and then click Battery.
  2. Click Run once. The Battery Test begins.
  3. When the battery test is complete, the results are displayed on the screen. For additional battery information, click Battery Details.
If the test passes, continue with these steps:
1. Go to Start, search for Device Manager, and open this result.
2. Expand batteries.
3. Right-click on the ACPI option (usually the 2nd option) and select delete or uninstall. Follow the prompts.
4. Shut down the computer. 
5. Disconnect the charger.
6. Remove the battery.
7. Hold down the power button for 1 minute.
8. Insert the battery only.
9. Attempt to turn the battery on.
Please click “
Accept as Solution” if you feel my post solved your issue, it will help others find the solution.
ECHO_LAKE
I am an HP Employee
I was doing above mentioned process but after pressing F2, options were memory test, hard drive test but there wasn't any option of components test. I shuffled through all options but didn't found any components test option...... What next
@Sushant_golu
Please try Installing HP PC Hardware Diagnostics for Windows from this document
Let me know how that goes.
If you would like to thank us for our efforts to help you, go to the public post & give us a virtual high-five by clicking the "Thumbs Up" icon below, followed by clicking on the "Accept as solution" on my public post.
Have a great day ahead!
Asmita
I am an HP Employee
Diagnostic installed successfully. Laptop passed both tests AC adapter & battery check. Then what is the matter that led switches color to white whereas it's not fully charged.
@Sushant_golu
Please try these steps -
Step 1 Windows Updates -
1) In the search box, type and open Windows Updates.
2) Check for updates.
3) If the updates are available, click on install and restart the computer.
Step 2 HP Support Assistant Updates -
1) In the search box, type and open HP Support Assistant.
Download and install the BIOS, Chipset drivers from this link.
If the issues till persists, try re-installing the operating system. Back-up the data and try these steps - Using the HP Cloud Recovery Tool
Keep me posted.
Asmita
I am an HP Employee
