Windows 11 Support Center. -
- HP Community
- Notebooks
- Re: Laptop will not power on, power/charging LED blinks 9 ti...
04-28-2020 11:52 AM
Try a different external AC power adapter.
I have an HP Elitebook 840 G3 laptop with a failed 45w adapter (HP Part Number: 740015-002). If I plug in the failed power adapter, the charging LED blinks 9 times (8 full blinks and one quick half-blink), but the laptop battery will not charge nor power up off the adapter.
If I plug in a known-good power adapter, the charging LED lights up with a solid amber, to indicate that the adapter is detected and that the laptop battery is being charged.
04-28-2020 01:26 PM
Chargers, like all other hardware, eventually fail -- looks like yours did.
So what is it you're asking?
I am a volunteer and I do not work for, nor represent, HP
