Common problems for Battery
LAPTOP-VSU1D536
Why the battery LED beside the Power LED always blinks for many months since my 1 year purchase?
I observed that the battery LED Blinks a lot and recently I am facing weak battery issues and it is draining very fast for past many days but in recent few days it is discharging if I shut down below 50% and showing 0% when I power on . And  it is unable to charge fully.
1 REPLY 1
@NIL15
I reviewed your post and I understand that the battery is not getting charged completely and the light beside the charger is blinking.
Don’t worry, I assure you I will try my best to get this sorted.
What is the product number of your computer?
If the light beside the charger is blinking it means that the battery is not working correctly. I recommend you update the BIOS from the below link and check whether the issue is resolved.
https://support.hp.com/in-en/drivers
If you continue facing the issue, then reinstalled Microsoft ACPI-Compliant Control Method Battery under device manager.
Here is how you do it.
Step 1: Click the Windows “Start” button and right-click “Computer.”
Step 2: Click “Manage,” then “Device Manager.”
Step 3: Click the “Batteries” section. A list of devices will appear.
Step 4: Right-click the “Microsoft ACPI-Compliant Control Method Battery” device and click “Uninstall.”
Step 5: Click the “Action” menu item and “Scan for Hardware Changes” to reinstall the driver.
Restart the computer and the issue should be fixed.
Let me know how it goes and you have a great day!
P.S: Welcome to the HP Support Community 😊
If you wish to show appreciation for my efforts, mark my post as Accept as Solution. Your feedback counts!
Cheers!
Stay Home – Stay Safe
The_Fossette
I am an HP Employee
