Windows 11 Support Center. -
- HP Community
- Notebooks
- looking for replacement parts - hinges and top cover parts
02-24-2024 10:41 AM
the securing screws and hinges from mmy laptop have faiiled (again) . I'm looking for parts to replace the top cover and associated parts - if anyone has a laptop with replacement parts or a complete laptop that is inoperative, I would appreciate getting it/them to use my laptop without the taped up plastic parts. I wish HP had designed this strudier so the hinges are seceured with better (larger srews) and bigger bosses to prevent failute.
02-24-2024 11:01 AM - edited 02-24-2024 11:02 AM
The parts list for your specific laptop configuration is in the HP PartSurfer web document hyperlink below.
https://partsurfer.hp.com/partsurfer?searchtext=2NM70UA&searchby=product
You would probably have better luck searching for a broken or used laptop in the same model series as yours in your country's version of eBay or in the second hand market.
