cancel
Showing results for
Search instead for
Did you mean:
ArchivedThis topic has been archived. Information and links in this thread may no longer be available or relevant. If you have a question create a new topic by clicking here and select the appropriate board.
glawrence45
New member
2 1 0 0
Message 1 of 4
525
Flag Post
Battery Light Blinking - Power Source Plugged In, Battery Not Charging
HP Pavilion 13 x360 PC
The battery light is blinking white. It says that the power source is plugged in, but the battery is not charging. I've run a battery test and it came back as passed/ok. Any help is greatly appreciated.
0 Kudos
3 REPLIES 3
Guleria_123
Level 4
161 160 7 9
Message 2 of 4
Flag Post
As we have properly undertsood your issue you are facing issue in battery issues:
Please read this information if you can :
Common causes of the error plugged in not charging can be because of the following: Faulty charger. Some chargers supply power to charge the batteryseperately for the power to run the laptop.
Nitin singh guleria
0 Kudos
glawrence45
Author
New member
2 1 0 0
Message 3 of 4
Flag Post
Thank you! So you suggest getting a new adapter/charger then?
0 Kudos
Guleria_123
Level 4
161 160 7 9
Message 4 of 4
Flag Post
Yes if it can help you then you must go ahead.
Nitin singh guleria
0 Kudos
