Ready to level up? Join the Expert Program—
Hi All
This notebook does not power on. have tried without battery attached and after holding power button down for at least one minute for full discharge. The LED blinks 8 times (red / orange) above the power adaptor connection - no other lights. This happens whether I plug in the adaptor or attach the battery on its own.
Is the main bord at fault or is there another problem - why does the led blink and does anyone know why it blinks EIGHT times?
Thanks in advance
3 REPLIES 3
The charging port LED blinking usually indicates a power issue and this is usually the charger. Have you tried powering the notebook on with just the charger connected? If the same beavior exhibits, then it is a hardware component issue (charger being most likely).
By chance do you have another charger to try?
Signature
↙-----------How do I give Kudos?| How do I mark a post as Solved? ----------------↓
Hi Cloud_Strider
Yes, I have plugged in the charger without the battery attached - same result.
I also get the same result when I replace just the battery
(with the charger unplugged at the time) and it also blinks 8 times.
I have tried another known working charger (I'm currently using it on another notebook) - same result.
I have also tried these same connection proccedures after holding down
the power button (without battery and without charger connected) for at least one minute - can't remember the knowledge details but I picked this point from the net.
I think it may require a main board replacement.
I am also looking to find out why the notebook power LED blinks 8 times. Isn't there some kind of technical spec as to what the number of blinks means - eg 3 blinks = memory problem etc?
There are blink codes for the caps lock/num lock keys, but not for the charging port.
Hardware tests cause the caps lock or num lock keys to blink instead.
This document from HP indicates that a continuously blinking charging port is an insufficient power issue and a different outlet should be tried.
Did the different adapter that was used have the same power ratings? This is usually listed on the label of the adapter.
If trying a different outlet does not work, then I recommend contacting HP for a warranty service if it is under warranty.
With this being a commercial notebook model, I am not entirely certain what support it is under. I do know that commerical products typically get a different warranty period than a consumer notebook.
Signature
