Common problems for Connectivity Issues
We would like to share some of the most frequently asked questions about Printer Wi-Fi, Connectivity Issues and Offline Status. Check out this link: HP printer is offline or unavailable.
Hello, I recently bought a new HP 580 printer, but it connects to Wi-Fi extremely slowly, and sometimes not at all. I don’t know what else to do—I’ve searched everywhere. Can someone help me with some solutions?
1 REPLY 1
Hi @denis3232,
Thank you for posting your query. I will be glad to help you.
I understand your HP Smart Tank 580 printer to Wi-Fi can sometimes be challenging, but here are steps you can take to troubleshoot and resolve the issue:
Check Network Connection:
  • Ensure your Wi-Fi network is working correctly by connecting to it with other devices.
  • Move your printer closer to the Wi-Fi router to improve signal strength and connectivity.
Printer Setup:
  • Make sure the printer hardware is fully set up, including removing all packing materials and properly installing ink cartridges.
  • Verify that the Wi-Fi feature is enabled using the Wi-Fi button on the printer’s control panel.
Restart Devices:
  • Restart the printer, computer, and router. Sometimes a simple restart can resolve connectivity issues.
Wi-Fi Direct Setup:
  • If Wi-Fi connection remains problematic, use the printer’s Wi-Fi Direct feature to connect directly from your mobile device or computer for printing.
Software and Firmware Updates:
  • Ensure your printer firmware is up-to-date, as software updates can resolve known connectivity issues. Check for updates via the https://support.hp.com/us-en.
HP App:
Print a Wireless Test Report:
  • From the control panel, print a Wireless Test Report to diagnose connectivity issues. This report can reveal issues with your network settings and help guide corrective actions.
Wi-Fi Connection Status:
  • Verify the Wi-Fi connection status on the printer’s control panel to ensure it’s connecting to the right network.
    I hope this helps.
 Take care and have an amazing day!
Did we resolve the issue? If yes, please consider marking this post as "Accepted Solution" and click "Yes" to give us a helpful vote - your feedback keeps us going!
Jerry_57
HP Support
I'm an HP Employee.
If this reply helped resolve your issue, please select the Accept as Solution as it helps others in the community quickly find the answer they’re looking for.
And if you found this reply helpful, clicking Yes below is a great way to let us know we’re providing the support you need, as it encourages us to keep improving and sharing helpful guidance.
