Common problems for Connectivity Issues
We would like to share some of the most frequently asked questions about Printer Wi-Fi, Connectivity Issues and Offline Status. Check out this link: HP printer is offline or unavailable.
HP LaserJet Pro MFP M148dw
I have a Laserjet Pro MFP M148dw wireless connection problem
2 REPLIES 2
Hi @Joab13,
If you're experiencing wireless connection issues with your HP LaserJet Pro MFP M148dw, here are some troubleshooting steps you can try.
Check the Network Connection
  • Ensure your printer is connected to the same Wi-Fi network as your computer or mobile device. You can check this through the printer's control panel.
Restart Devices
  • Restart your printer, router, and the device you're trying to print from. This can often resolve connectivity issues.
Reconfigure Wireless Setup
  • Using the Control Panel:
    • Go to the printer's control panel.
    • Navigate to the Network settings.
    • Select Wireless Setup Wizard to reconnect to your Wi-Fi network.
  • Using WPS (if your router supports it):
    • Press the WPS button on your router.
    • Within two minutes, press the WPS button on the printer.
Update Printer Firmware
  • Check for any firmware updates for your printer. You can do this via the HP Smart app or by visiting the HP support website.
Reinstall Printer Drivers
  • Remove the printer from your computer's device list.
  • Download and install the latest drivers from the HP website.
Check Firewall/Antivirus Settings
  • Ensure that your firewall or antivirus software is not blocking the printer's connection. You may need to add an exception for the printer.
Use HP Print and Scan Doctor
  • Download and run the HP Print and Scan Doctor tool, which can help diagnose and fix printing and connectivity issues.
Factory Reset the Printer
  • If all else fails, consider performing a factory reset on the printer. This will erase all settings, so you'll need to set it up again.
I hope this helps.
Alden4
HP Support
Raj_05
HP Support Community Moderator
How do I factory reset my printer
