Windows 11 Support Center. -
- HP Community
- Printers
- Printer Wireless, Networking & Internet
- Wireless printer will not test print from control panel
08-27-2021 01:06 PM
Hi,
I've had the printer for 2 years. Worked fine. Last 2 months it will not print. Its online - blue light on and says wireless connected and also shows wifi details but says its offline when I send a print job via laptops and mobiles (all 5 in our house the same). Rebooted several times. Done absolutely everything on forums and online help, virtual assistant, HP scan and print doctor etc. Nothing. IT WILL NOT EVEN TEST PRINT FROM THE CONTROL PANEL! Most suggested solutions involve supposed problems from my laptop but don't explain why it wont print from any device or from the control panel. I signed up to instant ink and keep getting emails to say i need to connect the printer so they can check the ink levels but it is connected. Any ideas please - I'm ready to scrap it and but new - but not HP!
08-30-2021 11:43 AM
@mikey571, Welcome to the HP Support Community! I’m here to help.
I understand you are not able to print as it says offline. To assist you better, are you using the HP Smart app to print? Let us try these steps:
Try making a standalone copy from the flatbed glass and check if that works. By this, we can conclude if this is a hardware or a driver issue.
- Restart the wireless router, the printer, and the PC
- Make sure the printer and the PC are connected to the same wireless network. Either 2.4 or 5GHz network.
- If you have a Dual-band router and both 2.4GHz and 5GHz networks share the same name/SSID, the printer will not be able to connect to the network. In this case, contact your Internet service provider to assign different names to both networks.
If the above does not help,
On the printer screen, go to Setup > Network Setup > Restore network settings
Go back to Network > Wireless > Wireless setup wizard and select your network.
Print a Network Configuration Page
On the printer control panel, touch the Setup icon
Touch Tools.
Swipe down the display, and then touch Network Configuration Page.
A Network Configuration Page prints up to three pages of information.
Have a great day!
KUMAR0307
I am an HP Employee
08-31-2021 09:51 AM
Hi Kumar0307,
Thanks for replying.
The print suggestions you advise don't work. As I said in my post it won't print from the control panel, hp smart app, or anywhere!
I checked the router is on the 5Ghz network so I went into the printer settings and made sure that the printer is set the same, where it originally was both 2.4 and 5. Rebooted. Ran the wireless setup wizard and as usual it shows everything connected and gives all the network information - IP address, MAC address etc but still does not print!
08-31-2021 10:50 AM
If the printer is not printing test reports and if you are not able to make copies, it means this is a hardware issue.
Do you get a blank page or the printer does not respond at all?
The last thing to try would be a factory reset.
Keep me posted.
KUMAR0307
I am an HP Employee
