×InformationWindows update impacting certain printer icons and names. Microsoft is working on a solution.
Click here to learn moreInformationNeed Windows 11 help?Check documents on compatibility, FAQs, upgrade information and available fixes.
- HP Community
- Printers
- Connecting HP Officejet Pro 8600 to Verizon JetPack 4G-LTE
11-27-2018 10:31 PM
I do not know how old this post is but I was just having this exact same issue with my hp office jet and MiFi Verizon hotspot. I tried all of the mentiones suggestions but none worked. However I was able to find a fix and it is simple. All I had to do is change my “Band” on my Verizon jetpack hotspot from 5 GHz to the 2.4 GHz band. Bam! The printer found the network immediately after I made that change. Hope this helps.
- « Previous
- 1
- 2
- Next »
Didn't find what you were looking for? Ask the community
