×InformationWindows update impacting certain printer icons and names. Microsoft is working on a solution.
Click here to learn moreInformationNeed Windows 11 help?Check documents on compatibility, FAQs, upgrade information and available fixes.
- HP Community
- Printers
- HP Color Laser jet Pro MFP M281CDW- "Supply Problem"
11-08-2020 07:36 PM
HaHaHa on HP. That worked. Thank you so much. This was soooooo chicken s#@t of HP to do this. I just wasted an hour of my life going through this so I could print out my kids' homework for this week. After this anti-customer act by HP, I will NEVER buy an HP Product again. I will trash my printer and buy any other brand before I buy your over-priced GD toner. I was going to buy a new printer next weekend for the upstairs. Guess what brand it won't be. HP, you blew it!
11-08-2020 07:39 PM
https://www.reddit.com/r/printers/comments/jpgpp3/hp_laserjet_pro_m280_m281_printer_series_20200612/
This site has it. Worked for me. Never buying HP again after this anti-customer behavior.
11-08-2020 07:42 PM
I got it from this link. After doing factory reset, it finally took. Printing again. Never buying HP again. Totally Anti-customer.
11-08-2020 08:50 PM
@JWK21 - This is exactly my problem. I cannot do anything with the firmware because the minute I connect to the network cable or wireless the printer reboots continuously. Once off the network the printer works fine via a USB direct cable connection. I have also deleted all the print queues from all machines accessing the printer.
Since it was the HP firmware upgrade that caused the issue it would be nice if HP took an interest or provided some level of meaningful support. Apparently HP initiated the firmware upgrade because of a security issue that was stated in a bulletin.
With a little luck and customer concern maybe someone will respond with some level of assistance. However, you may have come up with the best solution. I know HP will send their team into the stores during the holidays, I might go in and share the real customer experience with potential customers. Nothing like self-serive turning into a screening process shielding support from customers.
11-08-2020 10:49 PM
I found this link which mentions updating using a usb drive. I have not used this method but thought maybe it'll help someone.
"https://www.amexclusive.com/faq/hp-update-firmware"
11-08-2020 11:00 PM
For one that has the original cartridges from HP, and was bricked as well (with the 79 service error), bless you! For anyone else reading this, I unplugged the wired cable and turned off wifi. I then let it boot up. It was stable (not always the case, but keep trying). Once that happened, I turned wifi back on, quickly read off the IP address, and did the ftp. Worked like a charm. I used the 20190419 version because until this fiasco, there hasn't been enough difference to care. I also took CrookedFirmware's advice and disabled checking for updates. This printer can live out its life on the version its on!
Again, thank you so much!!
11-09-2020 09:37 AM
@Mike10500 - First get the printer off the network, disconnet network cable or wireless (switch off transmitter). If you can get the firmware file, when you open it the program a virtual drive will come online and the .app file will be present (.dmg file in the case of a mac). Once you open the .app file (Firmware updater) the drive process will begin, Discovery identifying your printer etc.. Once the printer will be identified and will walk you through the process. The challenge looks like getting the the last version of the firmware. Looks like there are some solutions for windows here, I am still looking for the mac file. Good luck.
11-09-2020 11:09 AM
Hi Bear048, you seem to know what your talking about, I too have a mac and cannot find a solution anywhere, If you find one could you perhaps let me know? Desperate times but I have no printer now down to them bad people at hp.
thanks Ross
Didn't find what you were looking for? Ask the community
