cancel
Showing results for
Search instead for
Did you mean:
    Know the Benefits of your HP account
    Connect with HP support faster, manage all your devices in one place, view warranty information and more– Click Here
    Fix Windows 10 Update Issues
    Resolve Windows 10 or update issues on HP computer or printer– Click Here
Highlighted
New member
2 1 0 0
Message 1 of 3
82
Flag Post
Problem with Ink system on HP Pro 8600
Hello HP Community,
I have got an Old stock HP OfficeJet Pro 8600  and tried to install it for the first time and keeps on getting message on the screen ''Remove cartridges & inspect for leaks. Do not use leaky cartridges. Re-install cartridges if okay.
Can someone assist me on this.
Thanks
2 REPLIES 2
Highlighted
HP Support Agent
HP Support Agent
5,774 5,745 342 379
Message 2 of 3
Flag Post
Hi @PrintTech_2020,
Let's try a power reset on the printer
Reset the product
  • With the printer turned on, disconnect the power cord from the rear of the printer.
  • Unplug the power cord from the wall outlet.
  • Wait at least 60 seconds.
  • Plug the power cord back into the wall outlet.
  • Reconnect the power cord to the printer.
  • Turn the printer on. HP recommends plugging the printer directly into a wall outlet.
Please remove the ink cartridges and inspect them for leaks.
If found leaking,  I'd suggest you Contact HP in your region for assistance.
And, Welcome to the HP Support Community.
Click the “Kudos, Thumbs Up" on the bottom right to say “Thanks” for helping
0 Kudos
Highlighted
Author
New member
2 1 0 0
Message 3 of 3
Flag Post
Dear Jay_G24,
Thanks for your response and solution.
But unfortunately it did not work.
I appreciate your time and effort, kindly suggest next step for action if you know any.
Regards
0 Kudos
Warning Be alert for scammers posting fake support phone numbers and/or email addresses on the community. If you think you have received a fake HP Support message, please report it to us by clicking on "Flag Post".
