    Check documents on compatibility, FAQs, upgrade information and available fixes.Windows 11 Support Center.
Hp officejet pro 8600 premium
I would like to replace the dispensing tray on my printer the tray is broken I also would like to know what is the updated version of my printer the Officejet pro 8600
1 REPLY 1
Hi @Theresasp57,
I’d recommend you contact HP Phone Support in your region for replacement options or to purchase printer parts.
Follow the instructions below to reach them:
1) Click on this link - https://support.hp.com/us-en/contact-hp
2) Select your product type below.
3) Enter the serial of your device.
4) Select the country from the drop-down.
5) Select the chat or get phone number options based on your preferences.
6)Fill the web-form and proceed further.
If you are having trouble navigating through the above options, it's most likely because the device is out of warranty. If yes? please send me a private message with the region you are contacting us from. Check next to your profile name, you should see a little blue envelope, please click on it.
Have a great day!
And, Welcome to the HP Support Community.
