Windows 11 Support Center. -
- HP Community
- Poly Phones
- Desk and IP Conference Phones
- Poly Edge 220 replacement parts
09-25-2024 11:38 AM
Just installed 30 Poly Edge 220 phones. Found that the little plastic tab that holds the handset in the cradle is very loose after rotating it for wall mounting. Have lost one already, others will get lost. Superglue to the rescue. How can I obtain replacements and/ or extras? Thanks
Solved! Go to Solution.
09-25-2024 12:42 PM
Hello @JPerry4 ,
welcome to the HP Poly community.
From our VoIP FAQ:
Aug 22, 2024 Question: Is there a part number to order replacement Hookswitch tabs for Edge E phones??
Resolution: Please see the below part numbers for Hook Switch tabs for Edge E Phones
8F3R4AA | Poly Edge E100/220 Hook Tab (25 Pieces) |
8F3R5AA | Poly Edge E300/320/350/400/450/500/550 Hook Tab (25 Pieces) |
Pretty sure the community search should have found >this<
Best Regards
Steffen Baier
09-25-2024 12:42 PM
Hello @JPerry4 ,
From our VoIP FAQ:
Best Regards
Steffen Baier
