[FAQ] How can I set up a conference or how many participants can be in the conference?, Click here to find out!
Edge B20
Hi ,
We installed Poly Edge B20 Phones. with the hardware version A and software version is 1.0.1 ( Build 5585M).
we installed with asterisk pbx. and the problem is the Poly edge B20 handset not ringing sound when i call from the other extension,
anybodi can help me ?
regards,
fahmi
3 REPLIES 3
Hello @Fahmi0071 ,
welcome to the HP Poly community.
the software you are using is no longer supported. A current software is 1.1.0.6355
What do you mean by Handset not ringing sound when i call from the other extension?
The phone itself rings if you get a call from another extension or externally. The Handset would only play back a call progress tone, the same as via loud speaker when you call another extension.
Please update the phone to a currently supported version. If you still have an issue I suggest you contact our Support organization in your region. Details are in my Signature.
Best Regards
Steffen Baier
Hi ,
It happened after 24 hour phone idle ( Standby ). next day i try to call that handset then the handset not heard ringing .
regards,
fahmi
Hello @Fahmi0071 ,
that is a completely different situation than originally explained and most likely a keep-alive or firewall issue. Please try and always have a full statement of what the issue is.
Our VoIP FAQ has this:
Jan 19, 2012 Question: How to troubleshoot Poly VoIP-related Issues?
Resolution: Please check => here <=
Other articles can be found and the link to the VoIP FAQ is in my signature.
I cannot troubleshoot your issue and if no other volunteer replies, I can only suggest you contact our Support organization in your region. Details are in my Signature.
Best Regards
Steffen Baier
