Windows 11 Support Center. -
- HP Community
- Notebooks
- Battery issue and battery charging indicator
09-04-2019 09:45 PM
I bought this HP notebook in may and now after almost two months there are issues (did not expected this with such a reputed brand ).3 out of 4 times, while charging, the led indicator turns white after some time even when the laptop is not fully charged.
When this happens the adapter gets very hot( charging continues).I ran the battery troubleshooter and it says no issues were found and the battery status is "ok".Only once it said that battery needs immediate replacement(in HP support assistant) but that error went away once i ran the HP battery check. I am currently using the latest windows 10 64-bit and have all the required apps updated to the latest version. There is no change in the charging speed.
Solved! Go to Solution.
09-07-2019 10:23 AM
Welcome to the HP Support Community!
I recommend you update the BIOS from the below link and check if it helps.
https://support.hp.com/in-en/drivers
If you continue facing the issue, then reinstalled Microsoft ACPI-Compliant Control Method Battery under device manager.
Here is how you do it.
Step 1: Click the Windows “Start” button and right-click “Computer.”
Step 2: Click “Manage,” then “Device Manager.”
Step 3: Click the “Batteries” section. A list of devices will appear.
Step 4: Right-click the “Microsoft ACPI-Compliant Control Method Battery” device and click “Uninstall.”
Step 5: Click the “Action” menu item and “Scan for Hardware Changes” to reinstall the driver.
Let me know how it goes and you have a great day!
If you wish to show appreciation for my efforts, mark my post as Accept as Solution. Your feedback counts!
Cheers!
The_Fossette
I am an HP Employee
09-07-2019 10:23 AM
Cheers!
The_Fossette
I am an HP Employee
