Here is the solution to resolve for 5 Long and 3 Short Blinks on your HP Laptop Click here to view the instructions!
Common problems for Battery
Victus by HP 16.1 inch Gaming Laptop PC 16-d0000 (2V8U5AV)
Hello!
I've purchased a new battery from the HP Parts Store and the laptop shows "Battery Counterfeit Check Error" message on startup. Additionally the battery doesn't work in the sense:
  • The laptop doesn't turn on without AC power;
  • The battery shows 0% charge in the Lock screen after start-up;
  • The battery shows 100% charge after Lock screen;
  • Turning off AC power immediately turns off the laptop;
I've tried all the steps recommended in this answer and it didn't help.
Thanks in advance for any suggestions!
@Dekeeta, Welcome to HP Support Community.
This behavior strongly suggests the battery is either faulty, not properly recognized, or potentially not genuine.
Verify the Part Number
Try a BIOS Update
Reset Embedded Controller (EC)
  • Shut down the laptop.
  • Unplug AC power.
  • Hold Power button for 15 seconds.
  • Plug in the adapter and try powering on again.
Check HP Support Assistant & Battery Report
  • Run HP Support Assistant to check battery diagnostics.
  • Run powercfg /batteryreport in Command Prompt and check if the battery is reported at all.
If these steps doesn't help, please visit the nearest HP authorized service center, the service team will check and assist you.
Kindly follow this link to locate the nearest HP service center: HP® Service Center Locator - United States | HP® Support
(Select the country from the dropdown menu and enter the city name or pincode)
I hope this helps.
Please click “Accepted Solution” if you feel my post solved your issue, it will help others find the solution. Select "Yes" on the bottom left to say “Thanks” for helping!
Max3Aj
HP Support
1 REPLY 1
Try a BIOS Update
  • Unplug AC power.
I hope this helps.
Max3Aj
HP Support
