Windows 11 Support Center. -
- HP Community
- Notebooks
- Notebook Operating System and Recovery
- HP Spectre x360 13-inch (2017) heat problems/fan noise
02-08-2018 06:03 AM
same issues here! fan constant and battery life horrible! I have not seen anything like this in the reviews...which I doggedly read before buying this laptop! I am now regretting chosing this over the Dell. what is wrong with HP!? These are supposed to be premium laptops! Not like this is the first version for them to fix this issue!
08-01-2018 01:24 PM
How I wish I had seen this thread before I commited to a £1500 purchase! I've had my Spectre for 7 days now and all of sudden I noted the fan was extremely loud and nearly gave me 3rd degree burns on my thighs!
I have also updated the BIOS, Chipsets etc etc... but for anybody reading this I wouldn't waste your time. I'd recommend returning your laptop if you have the option and choosing a different brand.
I gave HP chance as the Spectre looks sleek and stylish and has a great spec.
Unfortunately I will be returning my spectre to the retailer and probably move over to a Dell XPS.
HP should probably stop manufacturing these laptops until they've identfied the root cause to the fan issue and ultimately stop mugging off their customers.
01-03-2020 11:05 PM
We bought two of these laptops based on our loyalty of HP products and have been sorely disappointed. We went back to the retailer where we bought them almost immediately and were told the heat and noise issue is nothing to be concerned with - it is normal. It is not nothing!
On one of our systems the fan finally gave up the ghost and died. Both systems continue to get extremely hot when using (I actually got burn marks on my legs even though I put protective coverings on before using my laptop). When I contacted HP, I was told it is out of warranty and there is nothing to be done - they just run hot. I must say I am disappointed with HP. I have owned businesses and have used HP products both in my businesses and for my family and have never had as many issues as I have had with these two. The heat is my main issue (I am guessing my fan is fried and my entire system is not far behind), the noise is secondary. It is a very noisy running system. I'm not sure I would buy another HP at this point. Maybe it is time for us to look at some other manufacturers. 😞
01-04-2020 02:12 PM
@Erin_F1 Welcome to HP Community!
I understand your concern and I have brought your issue to the attention of an appropriate team within HP.
They will likely request information from you in order to look up your case details or product serial number.
Please look for a private message from an identified HP contact.
Additionally, keep in mind not to publicly post personal information (serial numbers and case details).
If you are unfamiliar with how the Community's private message capability works, you can learn about that here.
Thank you for visiting the HP Support Community.
- « Previous
- 1
- 2
- Next »
