Stop the Jumping Cursor! Quick Fixes for HP EliteBook Folio 1040 G1Click here to view the instructions!
ENVY 17-K112NL
Hi.
After windows 10 update my laptop does not sut down completely.
The screen becomes black but the fan is still running and power led is on. To turn it off I have to push the power button for 5 sec.
I tried to update BIOS, to change BOOT order - doasn't work.
Can You halp me?
9 REPLIES 9
I think it goes into sleep mode when you shut it down!
Probably, but the problem is that I can't wake it up without restarting.
You can get in your BIOS and restore the default settings, set the Boot order default.. and check again
I tried it before changing the Boot order. Then I tried to play with combinations of order. In the end I restored default. But it didn't work.
Tried all so to remove battery and a charger and to push for 30 sec the power button. After restarting I tried to switch it off, and... It works!!!
But, after an hour I tried ones more, and nothing!! The problem is NOT resolved. 😞
Are you sute that all the drivers are updated to it's latest?
I updated windows 29/07 and in the same day was updatet NVIDIA driver.
Than the first update I found with HP Support Assistant was System BIOS Update 01/08. - problem remain
After your message I controlled for the updates and I found some, but I don't really think that thay can change something:
- HP System Event utility
- Simple pass
- Wireless button
- HP 3D DriveGuard Software - perhaps?
After update and restart i used my laptop for some time and once again tried to swich it off - works.
I'll try to use it a little bit longer an write back here later.
By the way, thanks to you all for your ansvers for the moment.
and he problem remain.
searching in google i notice that that problem has allways been after windows update from 7 to 8 and now from 8,1 to 10.
Than I called to HP Service and they told me to downgrade windows back to 8.1 cause I'm the 7-th today who call with this problem and probably for the next 2 months will be some upd that resolve it. 😞
After a year of using my laptop without a problams, AGAIN I faced up the same issue! Now I knew how to solve it BUT, there is a NEW problem, I can't install Intel MEI v.9.xx... !!
