Windows 11 Support Center. -
- HP Community
- Notebooks
- Notebook Wireless and Networking
- No wifi connection when on battery power
09-18-2018 11:47 PM
When ever I try and use my laptop on battery power the wifi drops out. It shows it's connected but I cannot browse. Things I have tried - Update card to latest driver, set all battery settings to maximum performance, turn off "let this device turn off" I have even gone as far as replace the battery. I am out of ideas. I'm starting to think it's something to do with a windows update. Any help appreciated.
09-20-2018 12:07 PM
Welcome to HP Forums,
This is a great place to get support, find answers and tips to your technical queries.
The computer will drop its wireless connection when it is unplugged from the AC adapter and starts using battery power. This happens because the power settings are configured to automatically reduce the power to the wireless network adapter, resulting in a smaller broadcast radius. When the broadcast radius falls outside the range of the access point's broadcast radius, the wireless adapter disconnects. Although the device manager can be set to turn off the wireless device to save battery power when the power level is low, this can cause the wireless device to quit while still operating on battery power.
Click on this link: https://support.hp.com/id-en/document/c02693493 follow both.
- Adjust the wireless network adapter power settings
- Disable the wireless device's power saving option
Keep me posted, how it goes!
If the information I've provided was helpful, give us some reinforcement by clicking the Accepted Solution and Kudos buttons, that'll help us and others see that we've got the answers!
Have a great day!
Cheers:)
Raj1788
I am an HP Employee
09-20-2018 10:33 PM
Hi, thanks for your reply.
I have tried both of the things you suggested plus many more.
It never use to happen when I was operating from battery power, that's why it makes me think it is a windows update that has caused it.
What good is a laptop if you can't unplug it?
09-21-2018 01:49 PM
Thanks for the reply.
I suggest you connect the ethernet cable and uninstall the wireless drivers
click on this link: https://support.hp.com/in-en/document/c03467905 install the wireless drivers Using HP Support Assistant
Keep me posted!
Cheers:)
Raj1788
I am an HP Employee
09-24-2018 09:19 AM
I'm the Riddle_Decipher & I'm writing on behalf of my colleague @Raj1788, as the tech is out for the day, that said, I have reviewed your concern and the entire conversation, did some research and here's what I recommend:
Go to start, open Control Panel then open Power Options; now you have to click onChange plan settings right in front of "Balanced (recommended)" - below " Plans shown on the battery meter - after that click on Change advanced power settings now all you need is to find (Wireless Adapter Settings => Power Saving Mode => On battery) and change On battery to Maximum Performance. That's all.
To finish hit the "OK" button.
Keep us posted,
(We shall troubleshoot as a team, fight till the end and emerge - "victorious")
If you would like to thank us for our efforts to help you,
Feel free to give us a virtual high-five by clicking the 'Thumbs Up' icon below,
Followed by clicking on the "Accept as solution" button.
Have a great day!
Riddle_Decipher
I am an HP Employee
Learning is a journey, not a destination.
Let's keep asking questions and growing together.
09-25-2018 08:09 AM
Thanks for the reply,
Appreciate all your time and efforts,
I have sent you a private message, for more details that cannot be shared in a public post.
Can you please check your inbox on the forums page for the private message.
Have a great day!
Raj1788
I am an HP Employee
10-10-2018 03:04 PM
Thank you for joining HP Forums.
This is a great place to get support, find answers to your technical queries.
To provide you with an accurate solution, I'll need a few more details:
Could you please help me with the exact model name and the operating system of your PC?
Have you tried all the steps mentioned in the previous post?
Are you facing this issue after an update?
How long are you facing this issue?
Eager to assist you!
Cheers:)
Raj1788
I am an HP Employee
