Power LED Blinking Orange/White.
i am using a compaq cg56-102tu laptop. i wont turn on and nothing happens when i press the power button and theres a blinking orange and white light at the power indicator LED when the battery or ac adapter is connected..
courtesy of vaiost
it is like that when i plug the laptop on an outlet with or without the battery..it is the same when i only use the battery but it starts blinking when i connect the battery even without pressing any button..Any ideas?
3 REPLIES 3
Hello @NoGameNoLife,
I have read your post on how your notebook computer is not able to power on, and I would be happy to assist you in this matter!
Since there is a blinking orange light where the AC adapter plugs into your computer, I recommend following this document on Computer does not start and the LEDs blink or the computer beeps, as well as Using and Testing the AC Power Adapter. This should help to restore the power to your notebook.
If the issue persists, please call our technical support at 800-474-6836. If you live outside the US/Canada Region, please click the link below to get the support number for your region.
http://www8.hp.com/us/en/contact-hp/ww-phone-assist.html
I hope this helps!
Regards Smiley Happy
MechPilot
I work on behalf of HP
Please click “Accept as Solution ” if you feel my post solved your issue, it will help others find the solution.
Click the “Kudos, Thumbs Up" on the right to say “Thanks” for helping!
Thanks for the help..
Got it working by removing the battery, ac adapter and leaving it over night then holding the power button.
Hello again NoGameNoLife,
That is fantastic news!
If this answer has solved your problem, can you please mark it as an accepted solution? This will help others with the same issue to find the answer they are looking for.
Have a great rest of your day! 🙂
MechPilot
