If you're having print quality issues Click here for more tips!
HP Officejet Pro 8600 Plus e-All-in-One Printer - N911g
problem with printer and ink system
1 REPLY 1
Hi @Gatabout ,
Welcome to The HP Support Community.
I understand you're having issues with your HP Officejet Pro 8600 Plus e-All-in-One Printer related to the printer or ink system, here are some troubleshooting steps you can try:
Check Ink Cartridges:
  • Ensure that the ink cartridges are properly installed and seated.
  • Remove and reinstall the cartridges to ensure a good connection.
  • Check for any protective tape or packaging that might still be on the cartridges.
  • Replace any cartridges that are low or empty.
Clean the Cartridges and Printhead:
  • Go to the printer's control panel and select the option to clean the printhead. This can often resolve issues related to print quality and ink system errors.
  • You might also need to manually clean the contacts on the cartridges and printhead with a soft, lint-free cloth.
Reset the Printer:
  • Turn off the printer and unplug it from the power source. Wait for about 60 seconds before plugging it back in and turning it on. This can help reset any temporary issues with the printer.
Check for Firmware Updates: Update the firmware on an HP printer
  • Ensure your printer has the latest firmware installed. Check HP’s website for any available updates and follow the instructions to update the firmware if necessary.
Check for Error Messages:
  • If the printer displays any specific error codes or messages, look them up in the printer's user manual or on HP's support website for more targeted troubleshooting steps.
Run Printer Diagnostics:
  • Use the printer’s built-in diagnostic tools to check for and resolve any issues with the ink system.
Inspect the Printer for Obstructions:
  • Check for any paper jams or obstructions in the paper path that might be affecting the printer’s operation.
Reinstall Printer Software:
  • Uninstall and then reinstall the printer’s software on your computer. You can download the latest version of the software from HP’s website.
Refer to this document:  HP Officejet Pro 8600 Plus e-All-in-One Printer - N911g User manual
HP OfficeJet Printers - Resolving 'Print System Problem', 'Problem with Ink System' Errors
I hope this helps.
Please click “Accepted Solution” if you feel my post solved your issue, it will help others find the solution.
A_Gayathri
HP Support Community Administrator.
