If you're having print quality issues Click here for more tips!
HP Officejet Pro 9010
My officejet Pro 9010 (bought about 6 months back) has had its first cartridge replacement. Even after installing new HP ones, I got a 'Supply System problem' indicating 'cyan' as the issue. I have done the reset, took the cartridges out and back in but the problem persists.
1 REPLY 1
@AmolVsh
Welcome to the HP support community.
I understand that you are getting a cartridge error, follow these steps to fix the issue.
Clean the ink cartridge electrical contacts
Remove any debris or buildup from the contacts on the cartridges.
  1. Open the door or lid to the cartridge access area. Wait until the carriage stops moving before continuing.
  2. Push in on the cartridge indicated in the error message to release it from the carriage.
    Removing the ink cartridge
  3. Wipe the copper-colored contact on the cartridge with a lint-free cloth.
    Cleaning the contact on the ink cartridge
  4. Slide the cartridge into its color-coded slot until it clicks into place.
  5. Repeat these steps for any other cartridges indicated in the error message.
  6. Close the door or lid to the cartridge access area.
Refer to this HP document for more assistance:- Click here
Let me know how it goes.
To thank me for my efforts to help you, please mark my post as an accepted solution so that it benefits several others.
Cheers.
Sandytechy20
I am an HP Employee
