If you're having print quality issues Click here for more tips!
While dealing with exasperating Wi-Fi connection issues during the initial set-up of the printer, I decided to go ahead and fill the ink tanks. I inadvertently filled the wrong color ink in just one tank. Is there a way to swap tanks or drain it, without having to replace the entire printer? Any and all information would be helpful. Thank you in advance.
