I have a supply system problem with the Instant Ink Magenta cartridge.  I do not have another cartridge to replace it.  How can I solve the problem or get a new cartridge.  How do I chat with a live person instead of a virtual assistant that has wasted the last hour of my time.
1 REPLY 1
Hi @MissR2,
Welcome to the HP Support Community!
Thanks for reaching out!
We're thrilled to have the opportunity to assist you and provide a solution.
I understand you’re seeing an Instant Ink supply system problem with the Magenta cartridge, and you don’t have a spare to test with. Let’s go through a few steps to check what could be causing this, and I’ll also tell you exactly how to reach a live Instant Ink agent (not the virtual bot).
Reseat the Magenta Instant Ink cartridge
– Remove the cartridge, wait a few seconds, and reinstall it firmly until it clicks.
– Make sure no tape, dried ink, or debris is covering the contacts or printhead area.
Clean the electrical contacts
– Use a dry, lint-free cloth to gently wipe the gold contacts on the cartridge and inside the printer.
– Poor contact can trigger supply-system errors even if the cartridge has ink.
Restart the printer
– With the printer ON, unplug the power cable from the back and the wall.
– Wait 60 seconds, plug it back in, and let it reboot fully.
Make sure the printer is connected to the internet
– Instant Ink cartridges require an active, stable internet connection to authenticate.
– On the printer’s Wireless or Network menu, confirm it shows “Connected.”
Turn Web Services off and back on
– Go to the printer’s Web Services menu and disable it, then re-enable it.
– This refreshes the Instant Ink connection with HP’s servers.
I hope this helps.
I'm glad I could help! 😊 If this resolved your issue, please mark it as "Accepted Solution" and click "Yes" on "Was this reply helpful?" Your feedback not only keeps us going but also helps others find the solution faster! 👍
Take care and have an amazing day ahead! 🚀
Best regards,
I'm an HP Employee.
If this reply helped resolve your issue, please select the Accept as Solution as it helps others in the community quickly find the answer they’re looking for.
And if you found this reply helpful, clicking Yes below is a great way to let us know we’re providing the support you need, as it encourages us to keep improving and sharing helpful guidance.
