Hp laser jet pro 400 color mfp
I need help identifying this grayish roller part so i can order. It has a slit down the middle and it’s now leaving a white line down the page. Thanks for ur assistance.
2 REPLIES 2
Spoiler
Not sure if pictures show correctly. Please advise
appears to be the transfer belt you are pointing to. If you open the cartridge door and pull out the cartridges is the film that runs underneath?
If you find the information provided useful or solves your problems, help other users find the solution easier by marking my post as an accepted solution. Clicking "yes" on "was this reply helpful" also increases the chances that this solution will help others.
I am a volunteer, offering my knowledge to support fellow users, I do not work for HP nor speak for HP.
