Windows 11 Support Center. -
- HP Community
- Printers
- Printer Ink Cartridges & Print Quality
- Problem with supply system for magenta cartridge on HP Offic...
07-18-2024 05:19 AM
HP Officejet Pro 8720 new magenta ink cartridge won't print. Autoprompt says, "There is a problem with supply system. Try replacing the affected cartridge with a different non-empty cartridge. I did this. Printer is 5-6 years old, or more. Solution? Or, should I replace printer.
1 REPLY 1
07-18-2024 05:27 AM
Hello @iamivanhoe1 , how are you.
The procedures below may help with the error presented
https://support.hp.com/us-en/document/ish_1740122-1449154-16
If not, see if a technical assistant can support you.
HP® Service Center Locator - United States | HP® Support
Waiting
Welcome to the Community, I am a volunteer and private messages will not be answered.
If the answer was helpful and/or you would like to say "thanks", Click on the button“Yes” Did I help solve the problem? Don't forget click “Accept as a solution”, If anyone has the same question, this solution might be helpful.
Ask the community
