Windows 11 Support Center. -
- HP Community
- Printers
- Printer Ink Cartridges & Print Quality
- print or ink system problem
04-07-2025 04:06 PM
My inkjet 6600 has the following message
There is a problem with the printer or ink system. turn off, then on if the problem persists, contact HP.
I have shut down and restarted, I also have unplugged from wall and waited with no luck.
04-08-2025 11:50 AM
@Jillgokhalif, Welcome to HP Support Community,
Thank you for posting your query; I’m here to help by guiding you through steps to resolve this issue
Restart the Printer
- Turn off the printer.
- Unplug the power cord from the back of the printer.
- Press and hold the power button for 30 seconds.
- Wait for 60 seconds and connect the power cord back in.
- Turn on the printer.
Run HP Print and Scan Doctor (Windows only):
- Download and run the HP Print and Scan Doctor tool. Follow the prompts to diagnose and fix common printing issues.
Update Printer Firmware (Update the firmware on an HP printer | HP® Support)
- Go to the HP Customer Support - Software and Driver Downloads page. Enter your printer model number and search for the latest firmware update. Follow the instructions to download and install the firmware update.
Also, refer to this guide: HP Printers - An 'Ink System Failure,' 'System Supply Problem' or 'Supply System Problem' Error Disp...
I hope this helps.
Please feel free to reply here if you have any questions or if you need further clarification on any of the steps.
If my response helped, please mark it as an Accepted Solution! ✅ It helps others and spreads support. 💙 Also, tapping "Yes" on "Was this reply helpful?" makes a big difference! Thanks! 😊
Regards,
Garp_Senchau
I am an HP Employee
04-14-2025 06:27 AM
Hey @Jillgokhalif,
Let me know if you have performed the steps mentioned in this guide: HP Printers - An 'Ink System Failure,' 'System Supply Problem' or 'Supply System Problem' Error Disp...
You can perform a factory default on your device as a last resort. Restore factory defaults on your HP printer | HP® Support
I hope this helps
Regards,
Garp_Senchau
I am an HP Employee
